Help transforming component coordinates to assembly coordinates
I am trying to transform mass properties of a component from to it's own coordinate system into it's assembly coordinate system.
I can get the relative locations of the coordinate systems using the SW API example as show below. But this does not actually do the translation giving CG information relative to the next assembly coordinates.
Option Explicit
Sub OutputCompXform(swComp As SldWorks.Component2, nLevel As Long)
    Dim vChild                      As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim sPadStr                     As String
    Dim swCompXform                 As SldWorks.MathTransform
    Dim vXform                      As Variant
    Dim i                           As Long
    For i = 0 To nLevel
        sPadStr = sPadStr & "  "
    Next i
    ' Null for root component
    Set swCompXform = swComp.Transform2
    If Not swCompXform Is Nothing Then
        vXform = swCompXform.ArrayData
        ' Root component has no name
        Debug.Print sPadStr & "Component = " & swComp.Name2 & " (" & swComp.ReferencedConfiguration & ")"
        Debug.Print sPadStr & "  Suppr   = " & swComp.IsSuppressed
        Debug.Print sPadStr & "  Hidden  = " & swComp.IsHidden(False)
        Debug.Print sPadStr & "  Rot1  = (" + _
            Str(vXform(0)) + ", " + _
            Str(vXform(1)) + ", " + _
            Str(vXform(2)) + ")"
        Debug.Print sPadStr & "  Rot2  = (" + _
            Str(vXform(3)) + ", " + _
            Str(vXform(4)) + ", " + _
            Str(vXform(5)) + ")"
        Debug.Print sPadStr & "  Rot3  = (" + _
            Str(vXform(6)) + ", " + _
            Str(vXform(7)) + ", " + _
            Str(vXform(8)) + ")"
        Debug.Print sPadStr & "  Trans = (" + _
            Str(vXform(9)) + ", " + _
            Str(vXform(10)) + ", " + _
            Str(vXform(11)) + ")"
        Debug.Print sPadStr & "  Scale = " + Str(vXform(12))
        Debug.Print ""
    End If
    ' Recurse into subassembly
    vChild = swComp.GetChildren
    For i = 0 To UBound(vChild)
        Set swChildComp = vChild(i)
        Dim swCorrChildComp As SldWorks.Component2
        Dim swMod As SldWorks.ModelDoc2
        Set swMod = swComp.GetModelDoc2
        Set swCorrChildComp = swMod.Extension.GetCorresponding(swChildComp)
        OutputCompXform swCorrChildComp, nLevel + 1
    Next i
End Sub
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swConf                      As SldWorks.Configuration
    Dim swRootComp                  As SldWorks.Component2
    Dim bRet                        As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent
    Debug.Print "File = " & swModel.GetPathName
    OutputCompXform swRootComp, 0
End Sub
The resulting output is:
File = C:\\Documents and Settings\\jbass\\Desktop\\test.SLDASM
    Component = Part4^test-1 (Default)
      Suppr   = False
      Hidden  = False
      Rot1  = ( 1,  0,  0)
      Rot2  = ( 0,  .707106781186546,  .707106781186549)
      Rot3  = ( 0, -.707106781186549,  .707106781186546)
      Trans = ( 0,  0,  0)
      Scale =  1
    Component = Part2^test-1 (Default)
      Suppr   = False
      Hidden  = False
      Rot1  = ( 1,  0,  0)
      Rot2  = ( 0,  1,  0)
      Rot3  = ( 0,  0,  1)
      Trans = ( 0,  0,  .0254)
      Scale =  1
I am not sure where to go from here? My end result is that I need mass and CG of all components within an assembly relative to the global coordinate system.
SolidworksApi macros
