In the code below I am trying to "get" a pdf so that I can open it and print it from a .Net DLL. My current specific question is in the line .AddVariable("X",retVal(0)), where retVal(0) is the name of a file, what is the first parameter (that I have set to "X")?
More generally, how can I find documentation to this level? I have spent most of this afternoon trying to go through the EPDM API help. While I can find, for example, IEdmSearch7, I cannot find anything that documents the properties and methods of that class. Because this one implements IEdmSearch6, and that implements IEdmSearch5, I also looked at the documentation for those. Again, no luck.
So -- obviously hoping you can help with the first question so that I can move along with my project, but also hoping to figure out the documentation so that I don't have to keep asking questions and bugging people!
Thanks.
Dim search As IEdmSearch7 = vault.CreateSearch
Dim item As EPDMItemA = Nothing
'search = vault.CreateUtility(EdmUtility.EdmUtil_Search)
With search
.FindFiles = True
.FindFolders = False
.Recursive = True
.SetToken(EdmSearchToken.Edmstok_FindItems, True)
.StartFolderID = vault.ItemRootFolderID
.AddVariable("X", retVal(0))
End With
Dim result As IEdmSearchResult5 = search.GetFirstResult
If Not result Is Nothing Then
If result.IsKindOf(EdmObjectType.EdmObject_Item) Then
Dim file As IEdmFile8 = result
Dim edmItem As IEdmItem = file
item = New EPDMItemA(edmItem)
End If
End If
SolidworksApi macros
