Hello all,
I am trying to do a study into LED heat sink design and performance in Solidworks with the Flow Simulation, but I am getting results which I think are wrong (although this is most likely to do with how I set up the study).
Until now I had been using an external study, selecting Conduction in solids and Gravity from the wizard menus.
I applied a volume heat source to the part that is the LED COB in the assembly.
I then made a thermal joint between the bottom of the LED COB part and the surface of the heat sink which it is sitting on.
Finally I selected all the exposed faces of the heat sink and set a contact resistance of ground aluminium and air.
When I run the study and check the results the temperature throughout the whole heat sink is constant, i.e. it is, say, 100 degree C in ever part so there is no temperature gradient across any of the fins or in the sink.
Of course this cannot be but I do not see where I have made my mistake. I have seen mention of a 2-Resistor component on some other disucssion but am not sure how to apply this.
I am running the study using an assembly of parts, one of which is the heat sink and another one of which is the LED COB package. I have modelled this as a single part made of silicon, i.e. the entire package, not just the chip. Perhaps this is wrong?
Really stuck here so any help would be really appreciated!
Thanks in advance!
Jamshid
SolidworksFlow Simulation
a picture is worth a thousand words here to understand what your model looks like.
also, i'd suggest to start simpler. get rid of the thermal joint, get rid of the contact resistance. don't worry abotu 2R unless you have 2R data. modeling it as silicon is probably fine. i suspect the thermal resistance is your problem. not sure why you've selected that option for this type of analysis.
i'd also recommend going through all of the tutorials if you haven't done so already. they built upon each other so don't cherry pick the ones that look like they apply.
if you're still having trouble, please post the model or a report showing all the setup parameters.
Hi Jared,
Thank you for your reply.
I will put up a picture of the model shortly and hopefully it will help.
Actually, I had started out with just putting together the assembly, applying the volume source and running the flow simulation, but still had the same problem. All the body of the heat sink just appeared as the exact same temperature (very high!) as everywhere else. I will try to put a picture of the result I get as well if it helps. It was at that point when I tried to compare the set up to the initial study that was done using the Simulation tab (a thermal analysis) where I had to specify the conduction between the chip and also the convection condition for the fins. So it was just a matter of hoping that trying to mimic this in the flow simulation study would fix the problem (sadly it didn't!)
I have gone through most of the tutorials, but I will double check as you suggest and make sure I have gone through all the relevant ones.
Also, another reason why I tried the contact resistance and 2R conditions was that I noticed in what I think is a promotional video from solidworks (that actually tackles exactly what I am trying to do) these items have been used. The link to the video I am referrring to is given below. The temperature distribution on the heat sink in this study shows a niec clear gradient, but on mine the whole thing is just equally heated to a unrealistic temperature!
http://www.youtube.com/watch?v=PP0YgufCWBM
As a simple starting point then, what would you suggest is the best way to set up the model for flow simulation? The simplest I can think of is what I started with which was a volume heat source and that was all (unfortunatley I know that this gave me a wrong result so perhaps this arrangement is too simple!)
Thanks again for your help.
Regards
Jamshid
Hi Jared,
Please see attached images: the first one is just an image of the assembly, the second one is a picture showing the surface plot of temperature and the problem I am having.
Hope this helps.
Regards
Jamshid
start with a block with the same setup and post or post your model
Hi Jared,
I will try the same simulation but with just a block as you suggest. In the mean time I will also send you my assembly and simulation results shortly.
Thanks and regards
Jamshid
Hi Jared,
Please see attached the model as requested.
I tried re-running the simulation without the thermal joint and without the contact resistance. Only a volume source applied to the LED according to the lamp makers specs of expected heat generated but seems to result in the same error.
I have included the simulation results as well in case they would be of any help.
Thanks and regards
Jamshid
hi, what model should i be looking at and what study? the one i looked at in the main assy did not have a heat source applied. let's look at your block example when you get to it.
a couple notes on the one that you posted.
1. you had it as external and excluded the internal volume, i suspect that isn't really waht you want to do. please read up on this and start with a simpler example.
2. your model model was setup as transient, start with steady state.
if you're looking for some real one-on-one help on this, we do offer that here at hawk ridge. feel free to contact me at jared@hawkridgesys.com to discuss details.
Hi Jared,
There should be one assembly in the .zip file which I uploaded and that is the model which I am trying to run the studies on. In that assembly there is a yellow coloured LED COB, with part name "5W LED Chip". This is the part that I apply the volume source of 5.51W to when I set up the flow simulation study.
On the points that you made:
1) Initially I did indeed set up the study to exclude internal volumes or internal cavities without flow conditions, however I have also run the study simply as external without excluding anything, i.e. both the boxes for excluding space remain unticked. The results produced were still incorrect. Another point about internal space, if you notice there is an empty space in the plastic base part of the lamp with the 2 GU10 pins. This is to later be filled with a LED Driver at a later stage of the project. This will also generate a degree of heat but it's effects are being ignored for the time being. At the moment just concentrating on the heat sink.
2) The study which I have included is called "test 1" and can be found in the flow simulation tab under default. I did make sure not to tick the time-dependent box when using the flow simulation wizard but I will double check. (I may have run a transient thermal analysis from the Simulation tab, but this was at an early stage though but that's no longer what I am looking at).
Any advice will he helpful, so will be in touch to discuss, but for your info as I mentioned the video from solidworks which I posted earlier with the analysis of the LED lamp and heat sink is effectively exactly what this project is trying to achieve.
Thanks and regards
Jamshid
Post your checked model and your block test and we will go from there. I don think I'm working with the same files as you are. After you pack them, unpack and check them. Make sure the references are from the pack.
First you know about....
As I know, 2R is not support circular shape, Only support rectangular shape.
So you use lumped thermal conductivity or detail model or rectangular shape 2R model for LED
Actually, FS tutorial was provied like this case. Plz see the FS tutorials.
If using FS, It's easy to simulate in this case
See the below image
The importance of LED heat sink dissipation design
As we all know , LED is an energy-efficient light source , and it is loved by people because of its long lifespan . Although the LED has a low photoelectric conversion rate and a relatively low temperature , the temperature of the LED light source is much lower than that of an incandescent lamp whose operating temperature is as high as 2500C . However , LED has always been difficult to escape the many problems brought about by heat , so many designers in the design and development of LED lamps and realize that heat is a problem that cannot be ignored . Although LEDs still heat up , their temperature is relatively low , so this will not be a big problem . However , LED-based semiconductor devices should operate on / in temperatures below 100°C . According to the law of conservation of energy , heat (energy ) must be transmitted to nearby areas . The LED can only work between 25°C ambient temperature and 100°C maximum , with a temperature range of only 75°C . Therefore , a large heat dissipation surface and very effective thermal management are required . In theory , the LED's total electro-optic conversion efficiency is about 54% (theoretical value ) , and in reality , it is only 1/4 of the theoretical value ; the rest of the electrical energy will be released in the form of heat energy , which is why the LED must dissipate heat ; Cause temperature rise ;
1 . The temperature rise - resulting in a drop in luminous efficiency will make the LED lamp brightness decreased ;
2 . Temperature rise - main wavelength is affected : blue light drifts into / off short wavelength , other colors drift to long wavelength (red light ) , causing LED light color to change ;
3 . Temperature rise - correlated color temperature (CCT ) : The correlated color temperature of white light increases , and other color temperatures will decrease ;
4 . Temperature rise - ---- The forward voltage drops ; causing the current to rise affect LED .
5 . Temperature rise - --- increases / increased in reverse current ;
6 . Temperature rise - --- Increased thermal stress ;
7 . Temperature rise - shorten the service life of components ;
8 . Temperature rise - --- If led with phosphors , epoxy resin , temperature rise will lead to deterioration of these materials .
The above is only part of the high temperature has an impact on the performance of the LED part , the actual impact is far more than these , serious LED lamp will lead to failure.
