FAN - inlet pressure dependency on volume flow rate
Hello everybody,
Is it possible to define the environmental pressure at the inlet of a fan as a function of a goal?
If you use an external inlet fan and you click on “Thermodynamic parameters” - “Dependency”, you just have two options: “Constant” or “Formula definition”, but if you use “Formula definition” you can’t choose a goal as a parameter…
I want to impose the drop pressure at the inlet of the fan as a function of the volume flow rate through that fan.
Thank you in advanced,
Best regards
Teresa
SolidworksFlow Simulation
