SWx 2013 SP 5.0 does not finish launching. It gets hung when loading a script "C:/ProgramFiles/SolidWorksCorp/SolidWorks/data/taskpane/common/taskPaneFuncs.js".
Any Thoughts? I have tried the following:
Suggestion 1
1. Go to Control Panel > Internet Options.
2. On the Security tab > click Custom level.
3. Under Scripting, select Disable for Active scripting and for Scripting of Java applets.
4. Click OK.
5. Confirm the issue.
Did not work
Suggestion 2
2. On the Advanced tab under Browsing, deactivate the following items:
• Disable script debugging (Internet Explorer)
• Disable script debugging (Other)
3. Click OK.
4. Confirm the issue.
Could not locate “Disable script debugging (Internet Explorer)”
Did not work
Suggestion 3
2. On the Advanced tab, click Reset. You might need to restart the computer for changes to take effect.
3. Confirm the issue.
Did not work
I had multiple Autodesk products installed, and have since uninstalled. I think SWx and Autodesk may share part of the Flexnet license system. Thoughts?
