Connect points sequentially from two different linear patterns automatically
I'm trying to make tubes cut into a solid in the pattern of a truncated cone (think of a wasp nest kind of). I've made a linear pattern of 8x8 points in a 10x20 area, and then a linear pattern of 8x8 points in a 4x4 area. I want to put construction lines from point (1,1) in the 10x20 area to point (1,1) in the 4x4 area and so on through 64. I'm doing this so I can define the direction of the circular cut/extrusion from the larger area to the smaller area.
Is there a way to put construction lines in automatically without going point by point 64 times, or did I create my own sort of hell with this model?
I'd also take suggestions on a better way of doing this.
Thanks for the help!
SolidworksParts And Features
