Has anyone else had a problem with the computational domain or meshing after cloning a project?
I've had this a couple of times now on different models, after running a project I clone it and change a boundary condition value, e.g. increase a mass flow rate, then try to re run it. When it tries to mesh it doesn't seem to see the model and just meshes the entire domain as fluid. If I then change the computational domain slightly (make it slightly larger in one dimension, save it, then reset it) it then meshes properly again.
Any ideas what is causing this?
SolidworksFlow Simulation
