Hi all,
I am trying to figure out a macro that will allow me to change the font size for all Revision notes on a selected drawing.
I have worked out how to iterate through all the appropriate notes on a drawing but not how to change the font in each note.
i.e. if the Note is one character long and is surrounded by a triangle, then change the font size to x.xxmm
I have tried recording a macro to see what is being captured but it appears that there is an error in the recording.
This is the code that was recorded...
the code line: "Part.FontUnits 5mm" shows up in red within the programming environment...
Looking up the help file is seems to indicate that the code is correct, but...?
Removing either the 5 or "mm" from the line allows the code to run but with no effect on the selected "Note".
I know how to change the font on a global scale, but in this instance I want to only change the font within single character "Revision" numbers in the drawing.
Can anyone help?
Thanks in advance.
Brian.
SolidworksApi macros
