Change which configuration drives name in title block
Ok so I have a sheetmetal part drawing with a few formed views and a flat pattern view. Is there a way to change which configuation the drawing uses for its name?
Here is the macro I'm using in the title block: \\\$PRPSHEET:{SW-Configuration Name}
This macro pulls what ever configuration is used in the first view placed on the sheet. How can I change it to use a different configuration view other than the first one?
(The flat pattern was the first view used, so the title block says "XXXXSM-FLAT-PATTERN" I want to use the formed configuation view to drive the title block so the title block will reflect the correct configuation name.) Can it be changed after the view have been placed?
