I am trying to "write" a macro to change the document settings inside a drawing.
I want to change every occurrence where a FONT is used/specified to SWRomns.
I know "recording" has its limitations and issues but since I'm a novice it is a good starting point for me.
The code shown below does a decent job but there are several instances that are not changed.
' Macro1.swb - macro recorded on 10/23/17 by X
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Dim myTextFormat As Object
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingDimensionTextFormat, swUserPreferenceOption_e.swDetailingDimension)
myTextFormat.TypeFaceName = "SWRomns"
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingDimensionTextFormat, swUserPreferenceOption_e.swDetailingDimension, myTextFormat)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingBalloonAutoBalloons, 0, swLeaderStyle_e.swSTRAIGHT)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingAnnotationTextFormat, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingAnnotationTextFormat, 0, myTextFormat)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyle, swUserPreferenceOption_e.swDetailingRadiusDimension, swLineStyles_e.swLineCONTINUOUS)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDimensionsExtensionLineStyleSameAsLeader, swUserPreferenceOption_e.swDetailingRadiusDimension, False)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyleThickness, swUserPreferenceOption_e.swDetailingRadiusDimension, swLineWeights_e.swLW_THIN)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyle, swUserPreferenceOption_e.swDetailingHoleDimension, swLineStyles_e.swLineCONTINUOUS)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDimensionsExtensionLineStyleSameAsLeader, swUserPreferenceOption_e.swDetailingHoleDimension, False)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyleThickness, swUserPreferenceOption_e.swDetailingHoleDimension, swLineWeights_e.swLW_THIN)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyle, swUserPreferenceOption_e.swDetailingChamferDimension, swLineStyles_e.swLineCONTINUOUS)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDimensionsExtensionLineStyleSameAsLeader, swUserPreferenceOption_e.swDetailingChamferDimension, False)
boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDimensionsExtensionLineStyleThickness, swUserPreferenceOption_e.swDetailingChamferDimension, swLineWeights_e.swLW_THIN)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingWeldSymbolTextRootInsideFont, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingWeldSymbolTextRootInsideFont, 0, myTextFormat)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDetailingSectionViewLabels_PerStandard, 0, False)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingSectionView_RotationTextFormat, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingSectionView_RotationTextFormat, 0, myTextFormat)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDetailingDetailViewLabels_PerStandard, 0, False)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDetailingAuxViewLabels_PerStandard, 0, False)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDetailingOrthoViewLabels_PerStandard, 0, False)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingLocationLabelTextFormat, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingLocationLabelTextFormat, 0, myTextFormat)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingTableTextFormat, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingTableTextFormat, 0, myTextFormat)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingViewTextFormat, 0)
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.swDetailingViewTextFormat, 0, myTextFormat)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDetailingMiscView_PerStandard, 0, False)
End Sub
The instances that DID NOT CHANGE from my recorded macro (But I need to have change)
are here: (All are Document Properties inside a DWG)
Under Annotations
Balloons -> Text Font
Datums -> Text Font
Geometric Tolerancing -> Text Font
Notes -> Text Font
Surface Finishes -> Text Font
Weld Symbols -> Text Font
Under Dimensions
Angle -> Text Font
Anglular Running -> Text Font
Arc Length -> Text Font
Chamfer -> Text Font
Diameter -> Text Font
Hole Callout -> Text Font
Linear -> Text Font
Ordinate -> Text Font
Radius -> Text Font
I found the variable names for the Annotation items that still need to be changed.
swDetailingBalloonTextFormat
swDetailingDatumTextFormat
swDetailingGeometricToleranceTextFormat
swDetailingNoteTextFormat
swDetailingSurfaceFinishTextFormat
swDetailingWeldSymbolTextFormat
I do not know how to incorporate these into my macro.
I suspect I need to add the following for each variable?
boolstatus = Part.Extension.SetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.NAME-GOES-HERE, 0, myTextFormat)
Set myTextFormat = Part.Extension.GetUserPreferenceTextFormat(swUserPreferenceTextFormat_e.NAME-GOES-HERE, 0)
Is this correct?
How can I find the variable name for the associated Dimension Items that I also need to add?
Under Dimensions
Angle -> Text Font
Angular Running -> Text Font
Linear -> Text Font
Radius -> Text Font
I guess this is multi-part question.
Hopefully this is a step up from a "write this for me" type question.
I am a novice and I am using SW 2015 SP5.
SolidworksApi macros
