Hey,
So end goal is to create a buggy controller in labview which controls the motors of buggy in solidworks using soft axis. The problem im having is that when i apply the motors to the wheel in a higher order assembly the buggy will not move even though the wheels spin when the motors are applied in motion study. I have added gravity and contact between all four wheels and ground. Also added a Tangent mate between the wheels and the surface. When i run the motion study the wheels move but the buggy stays stationary.
I have attached my files it contains my buggy and the track. Also main assembly where the buggy track and floor/
Thanks.
Hope you can help this is for university project.
SolidworksMotion Studies
So after a lot fiddling and talking on IRC chat, i manged fix it. Turnm out the wheel assembly rim and tryer have to be locked. Also When setting up the motor you have to make one of the contacts on the floor.as seen in the screenshot.
Thanks
lock will make those parts move together, so i guess that could fix the issue if they weren't connected
