I found another bug! (big surprise)
In the Feature Tree I have a folder called "sump sketches". The folder contains two items sketch "F pipe shafts, pump", a plane "T` (lube line loci)". Immediately below the folder is another sketch "T` lube line loci" drawn on the preceeding plane.
Why can't I move the sketch into the folder???
Dialog: Cannot reorder. Change would put child feature before parent feature.
The sketch has one(1) parent, the plane! The plane has one child, the sketch. The plane has 2 parents; the Top plane (hence T`, and the sketch above it in the folder.
I'd understand if this was not the way folders were menat to be used -- BUT -- I have other folders in the project that are doing the *EXACT SAME THING*. This time it simply decided to stop working.
Will someone tell the fools at SolidWorks Corporate to fix these ***STUPID*** problems!!! My Feature Tree is several pages long. I wish to use folders to maintain some semblence of order -- that's the idea isn't it???
I realize that in the scope of bugs I usually complain about -- crashes destroying HOURS of work -- this is rather small potatoes. But what the hell is the problem with s'ware Q-A?
SolidworksSketching
