BOM Block export to autocad - block reference problems
When exporting a SWDrawing to autocad the block names for items including the BOM Table and other tables is the same so if a SW exported dwg is copied into another dwg with also a exported SW exported dwg all the text and info in the newly copied in drawing is reverted to what is already there - hence giving all bom tables the same text
is there an export function in SW that will break/explode the block reference and just make the tables text and lines so this double block reference issue doesn't happen - this can be done manually before copying dwg
Reason we want to do this is as a review of multiple assy in the same space where no SW program allows this and autocad allows us to line up and review in a more logical fashion
any help other than manually done at time of each copy to the matrix dwg
Todd
SolidworksImport/export
