"Auto" engrave placement on frame (Weld bolt, plates etc)
Hi
English is not my native language, so I really hope this makes sense. :)
Works on a lot of frames where the tubes is being cut in a tube cutting machines, and the placement for weld bolts, different plate etc is being engraved on the tubes for easy welding.
The company that cuts the frames prefers us to remove as much as possible, and only leave a few mm off the component so that the position is still marked
Here is a before/after picture showing how it looks right now. We manually cut away all the extra material so the frame is "clean", while still keeping the position of every component.
This is just a very small and simple frame. The frames are generally much larger, which means a lot of manual cutting to remove the extra material and prepare them for the tube-cutting machine.
Is there a way to show/keep the component positions on the tubes faster than what we are doing right now?
Thanks in advance!
Regards,
Henrik
