Hi
I have a three stage (one fixed and two moving) telescopic drive. Ihave limit mates set up so I can drag the end to extend and retractit.
The mechanics of the drive mean that the end section moves at twicethe speed of the middle section.
How do I set it up to behave like this? i.e. I want to drag the endsection a distance 'a' and the middle section to automatically move'a/2'
Thanks a lot!
JonSolidworksAssemblies
Thanks a lot!
In this simplified example you will find that you drag the top partback and forth with ease. The whole thing works so fast that anymachine should be able to do it. It's a very simple technique andworks quite well.
I won't say more at this point - consider it a puzzle to find thekey. Have fun. :-)
WT
Linear/Linear Coupler under advanced mates.
Do you have a simple example you could post, like take mine andapply it to those parts? I tried to set it up here and it justfully defined the parts - no movement ability left. Not sure why.
WT
Just like this.
Don
The advantage of this method is that it is straight-forward as amate, however barely defined in the Help. A disadvantage is thatyou have to get your parts in the proper relation to each otherfirst and then apply the mate. If you suppress the mate, then moveone of the pieces, then unsuppress the mate, then they will movetogether again at the prescribed ratio, but in the new relativepositions.
My method was developed years ago before this mate arrived on thescene. Thanks - I learned something today, as usual. :-)
WT
Don
Jon
