assembly holes from part to another part -linear pattern generated
Hi Everyone
I want to make steel connection between column and beam, so I used
a- part for the column
b-part for the beam
c-part for the connection or the joint
I am going to make the joint as smart component , but I have an issue here, I created some holes for the bolts connection with the column , I used linear pattern
when I edit the column to transfer these holes I want to convert entities which is the linear pattern , not to choose each one individual, because I could change the number of bolts and then I will get errors
so , please how to convert this linear pattern , and make the sketch in the other part always convert the pattern , what ever it is.
regards
AR
SolidworksAssemblies
