We use several parts in our designs that are purchased as full length items, like DIN rail, extruded wireways and such. Each of these items is brought in under our part number in ERP and allocated on a "as required" basis, then the shop takes, for instance, a 2 meter long part, cuts it down to what they require, and returns the rest to stock.
In CAD, we have typically added configurations to each of these models for every length that is required at the time, or perhaps isnt needed sometimes, with an overzealous designer adding length configurations for every 1/2" increment.
I proposed to my team that we simply add the full length part to our assemblies and use an assembly-level cut to shorten each instance to what's required.
I'm curious to hear what the community thinks about either of these methods or other ways of adding models to assemblies that start out as full length and get cut down in the shop as required.
Thanks.
"I proposed to my team that we simply add the full length part to our assemblies and use an assembly-level cut to shorten each instance to what's required.'
This is what I do. Especially since it is cut by the people doing the assembly and they have a bunch on hand that they are responsible for keeping stocked. I typically create a display state for the drawing showing the enclosure back panel with the various DIN rails and such with dimensions for their positions and cut lengths. I have a note (not a balloon) to each indicating the part number of the full length component. These parts are envelope parts in my assembly as well, so they don't show up on BOMs. Otherwise, a box with 3 DIN rails 6 inches long would trigger an order for 3 full lengths rails.
As for design intent, this IS design intent. I intend for the people assembling the box to cut the material to the dimensions shown.
Neither. You should focus on what you need according to design intents rather than how to cut or get it.
One thing not mentioned, but what we have to contend with/consider is the mounting holes/slots for items such as DIN rail and wireway.
Given required lengths aren't usually in sync with mfg spacings, we have to waste trim to get the correct placement (rail end to first slot for example), especially for 90° abutment placements.
As such, we can't just "lop off" one end at various distances from the other end.
To ensure we don't have the variance and since our quantities for such pieces are fairly high for repeated assemblies, we do the dedicated part with drawing (for those ones that warrant this).
