The purpose is to mate two components using one selected face from each of them. In other words, I intend to use a procedure that gets into the selected component and goes through all faces until it finds the one by name, selecting it. Therefore the procedure is called two times, after selecting each of the components individually, so both are traversed in its faces, and then having both faces selected.
The issue starts after selecting the first face when I try to get into the second component without succeeding in adding the following face to the selection list.
I would like to know how to have these two faces selected so I can proceed with the mate.
This is the code:
Sub mate_pino_porca()
Dim swApp As Object
Dim AssyDoc As Object
Dim longstatus As Long
Dim MyMate As Object
Dim CompName As String
Dim FaceName As String
Dim CCompName As String
Dim FFaceName As String
Dim boolstatus As Boolean
Set swApp = CreateObject("SldWorks.Application")
' Get active Assembly document
Set AssyDoc = swApp.ActiveDoc()
CompName = "porca quadrada-1@Assem_pino_porca"
FaceName = "concentrico_porca"
CCompName = CompName
FFaceName = FaceName
boolstatus = AssyDoc.Extension.SelectByID2(CompName, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
SelectComponentFaceByName CCompName, FFaceName
CompName = "pino-1@Assem_pino_porca"
FaceName = "concentrico_pino"
boolstatus = AssyDoc.Extension.SelectByID2(CompName, "COMPONENT", 0, 0, 0, True, 0, Nothing, 0) '<---If False it works!
Set MyMate = AssyDoc.AddMate5(1, 0, True, 0#, 0#, 0.001, 0.001, 0.001, 0#, 0#, 0#, False, False, 0, longstatus)
'Part.ClearSelection2 True
End Sub
Public Sub SelectComponentFaceByName(CompName As String, FaceName As String)
Dim swApp As Object
Dim swAssy As SldWorks.AssemblyDoc
Dim swComp As SldWorks.Component2
Dim SelMgr As Object
Dim SelData As SldWorks.SelectData
Dim Comp As Object
Dim Body As Object
Dim Face As Object
Dim CurFaceName As String
Const swSelCOMPONENTS = 20
Set SelMgr = AssyDoc.SelectionManager()
Set SelData = SelMgr.CreateSelectData
'AssyDoc.SelectByID "pino", "COMPONENT", 0, 0, 0
Set Comp = SelMgr.GetSelectedObject3(1)
'If (SelMgr.GetSelectedObjectType2(1) <> swSelCOMPONENTS) Then
'swApp.SendMsgToUser "Please Select an Assembly Component."
'Exit Sub
'End If
Set Body = Comp.GetBody() ' Get the Component Body
If (Body Is Nothing) Then
swApp.SendMsgToUser "Component Body Unavailable."
swApp.SendMsgToUser "Make sure not lightweight or suppressed"
Exit Sub
End If
'boolstatus = AssyDoc.DeSelectByID(CompName, "COMPONENT", 0, 0, 0)
Set Face = Body.GetFirstFace
' Traverse thru all body faces
Do While Not Face Is Nothing
' Call ModelDoc.GetEntityName.
CurFaceName = AssyDoc.GetEntityName(Face)
If (CurFaceName = FaceName) Then
'Face.Select (0) ' Select the face
boolstatus = Face.Select4(False, SelData)
Exit Do
End If
Debug.Print CurFaceName
Set Face = Face.GetNextFace
Loop
End Sub
Many thanks in advance!
Diogo Teixeira
SolidworksApi macros
