I have run program of create sketch of square using C# . Program runs without error but it is not creating any sketch in solidworks. unable to trace problem.
// Preconditions:
// 1. Open SolidWorks.
// 2. Verify the location of the part template.
// Postconditions:
// 1. Click the green check mark in the Modify dimension dialog
// (look for the hidden dialog behind your other windows).
// 2. 3DSketch1 is in edit mode and contains a spline and a corner rectangle.
// 3. The display dimension of 63.238 mm appears on the y axis starting at
// (-0.1, 0, 0.01111142101618) while the sketch is in edit mode.
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swconst;
using System;
namespace AddAlongYDimension_CSharp.csproj
partial class SolidWorksMacro
ModelDoc2 Part;
DisplayDimension myDisplayDim;
bool boolstatus;
int longstatus;
public void Main()
swApp.ResetUntitledCount(0, 0, 0);
Part = (ModelDoc2)swApp.NewDocument("C:\\\\Documents and Settings\\\\All Users\\\\Application Data\\\\SolidWorks\\\\SolidWorks 2010\\\\templates\\\\Part.prtdot", 0, 0, 0);
swApp.ActivateDoc2("Part1", false, ref longstatus);
Part = (ModelDoc2)swApp.ActiveDoc;
Part.SketchManager.Insert3DSketch(true);
object vSkLines = null;
vSkLines = Part.SketchManager.CreateCornerRectangle(-0.05171778666374, 0.01933785938058, 0.03, 0.08445537697179, -0.04142795937025, -0.03);
boolstatus = Part.Extension.SelectByID2("Right Plane", "PLANE", 0, 0, 0, false, 0, null, 0);
Part.ClearSelection2(true);
object pointArray = null;
double[] points = new double[12];
points[0] = 0;
points[1] = -0.03591009660795;
points[2] = 0.04608246573503;
points[3] = 0;
points[4] = 0.0147420284178;
points[5] = 0.005170989573514;
points[6] = 0;
points[7] = -0.006478053228363;
points[8] = -0.04282131900055;
points[9] = 0;
points[10] = -0.02294509596464;
points[11] = -0.09396066420243;
pointArray = points;
SketchSegment skSegment = default(SketchSegment);
skSegment = Part.SketchManager.CreateSpline2((pointArray), true);
Part.SketchManager.InsertSketch(true);
boolstatus = Part.Extension.SelectByID2("3DSketch1", "SKETCH", 0, 0, 0, false, 0, null, 0);
Part.EditSketch();
boolstatus = Part.Extension.SelectByID2("Point5", "SKETCHPOINT", 0, -0.03591009660795, 0.04608246573503, false, 0, null, 0);
boolstatus = Part.Extension.SelectByID2("Point4", "SKETCHPOINT", 0.08445537697179, 0.02732744880518, -0.01872625210654, true, 0, null, 0);
myDisplayDim = Part.SketchManager.AddAlongYDimension(-0.1, 0, 0.01111142101618);
Part.ViewZoomtofit2();
public SldWorks swApp;
SolidworksApi macros
