API Help! Creating a derived mirror configuration.
Hello, I am making the switch from lurking on the forums to asking a question.  The reason for this change is that I cannot find an answer to my problem anywhere I have looked.  Sorry if this is a simple request, but I have no formal training in making macros.
My problem is that I am trying to make a macro to created a derived mirror configuration of an open part file.  Manually we always open an assembly, insert the part and run the mirror function, ticking off the same selections each time.  I did not see any simpler existing way in SolidWorks 2016 so I decided to write a macro to do it.  Below is the code I have so far, however, I continually get a "Run-time error '438': Object doesn't support this property or method"  What am I doing wrong, what needs changed to make this work, or is there a simpler way to get the same result?  Thanks for any help.
Dim swPart As Object
Dim swAssy As Object
Dim Result As Long
Dim ActiveConfig As Object
Dim boolstatus As Boolean
Dim errors As Long
Dim warnings As Long
Public Sub CreateMirror()
    swApp.Visible = True
    Set swDoc = swApp.ActiveDoc
    Set swPart = swApp.ActiveDoc
    Set ActiveConfig = swPart.GetActiveConfiguration
    Dim ConfigName As String
        ConfigName = ActiveConfig.Name
    Dim PartPathName As String
        PartPathName = swPart.GetPathName()
        PartPath = InStrRev(PartPathName, "\\") + 1
        PartExten = InStrRev(PartPathName, ".")
    Dim PartName As String
        PartName = Mid\\\$(PartPathName, PartPath, PartExten - PartPath)
    Set swDoc = swApp.NewDocument("C:\\WTI-Vault\\WTI Templates\\Assembly.asmdot", 0, 0, 0)
    Set swAssy = swApp.ActiveDoc
    Dim AssyName As String
        AssyName = swAssy.GetTitle
    boolstatus = swAssy.AddComponent(PartPathName, 0, 0, 0)
    Dim MirrorPlane As SldWorks.Feature
    Set MirrorPlane = swAssy.FeatureByName("Right Plane")
    Dim CompToMirror(0) As Object
    Set CompToMirror(0) = swAssy.GetComponentByName(PartName & "-1")
    Dim NameModifier As String
        NameModifier = ""
    Dim DerivedName As String
        DerivedName = "_Mirror2"
    Dim CompToInstance As Object
    Set CompToInstance = Nothing
    Dim Orientations As Object
    Set Orientations = Nothing
    Dim OrientAboutCoM As Boolean
        OrientAboutCoM = False
    Dim CreateDerivedConfigs As Boolean
        CreateDerivedConfigs = True
    Dim NameModifierType As swMirrorComponentNameModifier_e
        NameModifierType = swMirrorComponentName_Custom
    Dim FileLocation As String
        FileLocation = Left\\\$(PartPathName, PartPath)
    Dim ImportOptions As Integer
        ImportOptions = swMirrorPartOptions_ImportSolids
    Dim BreakLinks As Boolean
        BreakLinks = False
    Dim PreserveZAxis As Boolean
        PreserveZAxis = False
    Dim FlexSync As Boolean
        FlexSync = False
    Dim DerivedMirror As Object
        DerivedMirror = swAssy.MirrorComponents3(MirrorPlane, CompToInstance, Orientations, OrientAboutCoM, _
                        CompToMirror, CreateDerivedConfigs, DerivedName, NameModifierType, NameModifier, _
                        FileLocation, ImportOptions, BreakLinks, PreserveZAxis, FlexSync)
    swApp.CloseDoc AssyName
    boolstatus = swPart.EditRebuild3()
End Sub
SolidworksApi macros
