API Drawing/Swept Cut Question
In my code I have a drawing that I am getting all the lines and arcs then I want to xfer that to a template part and make a swept cut. Everything works pretty well on the drawing part other than sometimes it leaves an arc out and I can't ever use the drawing for a swept cut unless I go edit it manually.
I am also wondering if anyone has an example of a swept cut using profile/path through api?
Here is my code to xfer the drawing.
    Dim swApp As New SldWorks<br>    Dim swModel As ModelDoc2 = swApp.OpenDoc("C:\\SolidWorksDrawings\\Test\\Edge.sldprt", 1)<br>    Dim swExt As ModelDocExtension<br>    Dim boolstatus As Boolean<br>    swExt = swModel.Extension<br>    boolstatus = swExt.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)<br>    swModel.EditSketch()<br><br>    Dim m As ISketch = swModel.IGetActiveSketch2<br><br>    Dim mLineCount As Integer = m.GetLineCount<br>    Dim mArcCount As Integer = m.GetArcCount<br>    Dim mArcs As Object<br>    mArcs = m.GetArcs()<br>    Dim mLines As Object<br>    mLines = m.GetLines()<br>    swApp.CloseDoc("C:\\SolidWorksDrawings\\Test\\Edge.sldprt")<br>    Dim swModel2 As ModelDoc2 = swApp.OpenDoc("C:\\SolidWorksDrawings\\Test\\Part3.sldprt", 1)<br><br>    Dim swExt2 As ModelDocExtension = swModel2.Extension<br><br>    boolstatus = swExt2.SelectByID2("Right Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)<br><br><br>    Dim skManager As SketchManager<br><br>    skManager = swModel2.SketchManager<br><br><br>    'There are 11 values per arc<br>    For i = 0 To mArcCount - 1 Step 1<br>      skManager.CreateArc(mArcs(i * 11 + 7), mArcs(i * 11 + 8), 0, mArcs(i * 11 + 1), mArcs(i * 11 + 2), 0, mArcs(i * 11 + 4), mArcs(i * 11 + 5), 0, mArcs(i * 11 + 10))<br>    Next<br>    'There are 7 values per line<br>    For i = 0 To mLineCount - 1<br>      skManager.CreateLine(mLines(i * 7 + 1), mLines(i * 7 + 2), 0, mLines(i * 7 + 4), mLines(i * 7 + 5), 0)<br>    Next<br><br>    skManager.InsertSketch(True)
Thanks in advance for any help
SolidworksApi macros
