Add a mate between a pre selected face and plane of assembly
Hi everyone,
I've been trying to create a macro to mate an inserted component in an assembly so that the selected face gets mated to a plane of an assembly (say, Top Plane). I've used the API Help Example, and have got the following so far. But it will fail to mate with unknown error.. Is there anything I'm missing here? Thanks in advance.
Dim swAssy As SldWorks.AssemblyDoc
Dim boolstat As Boolean, stat As Boolean
Dim strings As Variant
Dim AssemblyName As String
Dim AssemblyTitle As String
Dim SecondSelection As String
Sub Aligned()
    Set swModel = swApp.ActiveDoc
    Set swAssy = swModel
    ' Get title of assembly document
    AssemblyTitle = swModel.GetTitle
    ' Split the title into two strings using the period as the delimiter
    strings = Split(AssemblyTitle, ".")
    ' Use AssemblyName when mating the component with the assembly
    AssemblyName = strings(0)
    boolstat = True
    'planes to use for the mate
    SecondSelection = "Top@" + AssemblyName
    Set swDocExt = swModel.Extension
    'Select the planes to mate
    boolstat = swDocExt.SelectByID2(SecondSelection, "PLANE", 0, 0, 0, True, 1, Nothing, swSelectOptionDefault)
     swAssy.AddMate5 swMateCOINCIDENT, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0
End Sub
SolidworksApi macros
