Anyone come across this issue in trying to install the beta?
"You have selected products that cannot be installed from your current file
set. Additional files will need to be downloaded.
dotNetFx_dotnetfx45_full_x86_x64.exe, CheckForUpdates_sldCheckForUpdates.exe,
VCRedist_vcredist_x86.exe, VCRedist_vcredist_x64.exe,
VCRedist10_vcredist_x86.exe, VCRedist10_vcredist_x64.exe,
VCRedist11_vcredist_x86.exe, VCRedist11_vcredist_x64.exe, VBA_vba71.exe,
VBA_vba71_1033.exe, VBA_vba71-kb2783832-x64.exe, solidworkscore1of2.exe,
solidworkscore2of2.exe and swactwiz.exe"
I tried changing the download options but no other options allow me to check them.
Also,
The license page has a license number for Simulation but the next window gives a warning:
"Your serial number does not entitle you to SOLIDWORKS Simulation 2015. If your license is new, you may want to try again
later. Otherwise contact your reseller to verify that the number is correct. You will still be able to choose the products you want to install, but you will not
be able to download any installation files. If you continue without downloading enabled, you will need to provide a complete set of download source files or a
DVD from which to install.
Click Back to check the serial number you entered or enter a new serial number. If you continue without a validated
serial number, the Installation Manager will not pre-select the products to which you are entitled."
Anyone get this error too?
Thanks
SolidworksSolidworks 2015 Beta
