I am trying to use smartfastener to add a 5/8" hex bolt, then a flat washer on the top stack, and bottom stack, flat washer, spring washer and hex nut.
No matter how I pick, I can't get the bottom stack washers and nuts to not be "buried" in the middle of the bottom plate.
The washers show up fine on top. The I selected the top plate, but do I need to pick both plates, or the top plate cuts (yes someone else made them cuts before I started it).\\
I created the bottom "long" plate with holes, so maybe select that or both top and bottom plates?
Thanks in advance.
