Hello SolidWorks community,
I'm experiencing an issue with a custom Add-In I've developed for SolidWorks.
The Add-In loads and functions correctly when SolidWorks is first started. However, after a period of inactivity, it seems to stop executing—possibly being unloaded or disabled. Once I manually reload the Add-In or restart SolidWorks, it works again without any issues.
The Add-In is designed to:
Automatically switch the model view to ISO before saving.
Exit "Edit Sheet" mode in drawings before saving.
Has anyone encountered a similar issue or have any insights into what might be causing this behavior? Any suggestions on how to prevent the Add-In from becoming inactive would be greatly appreciated.
Thank you in advance!
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swcommands;
using SolidWorks.Interop.swconst;
using SolidWorks.Interop.swpublished;
using System;
using System.Runtime.InteropServices;
using System.Timers;
using Timer = System.Timers.Timer;
namespace SWXAddIn
[Guid("572956E4-6151-49A6-BAD2-ECB11A379B60")]
[ComVisible(true)]
public class SolidWorksAddIn : ISwAddin
private SldWorks? _swxApp;
private int _cookie;
private Timer? _reconnectTimer;
private DPartDocEvents_FileSaveNotifyEventHandler? _partSaved;
private DAssemblyDocEvents_FileSaveNotifyEventHandler? _assemblySaved;
private DDrawingDocEvents_FileSaveNotifyEventHandler? _drawingSaved;
public bool ConnectToSW(object thisSw, int cookie)
_swxApp = thisSw as SldWorks;
_cookie = cookie;
if (_swxApp == null) return false;
_swxApp.SetAddinCallbackInfo(0, this, _cookie);
_swxApp.SendMsgToUser("Rosenxt SolidWorks AddIn loaded");
_swxApp.TaskPaneIsPinned = true;
if (_swxApp.ActiveDoc is ModelDoc2 modelDoc)
ConfigureComponentIdentifiers(modelDoc.FeatureManager);
SubscribeToSaveEvents(modelDoc);
//_swxApp.CommandCloseNotify += OnCommandCloseNotify;
new OptionSetter(_swxApp).DeactivateToolboxDefaultSearchFolder();
StartReconnectMonitor();
return true;
private void StartReconnectMonitor()
_reconnectTimer = new Timer(60000);
_reconnectTimer.Elapsed += CheckConnection;
_reconnectTimer.Start();
private void CheckConnection(object? sender, ElapsedEventArgs e)
try
if (_swxApp == null || _swxApp.GetProcessID() <= 0)
ReconnectToSw();
catch
ReconnectToSw();
private void ReconnectToSw()
try
var swApp = SolidWorksConnector.GetActiveSolidWorksInstance("SldWorks.Application");
if (swApp is not SldWorks swxApp) return;
_swxApp = swxApp;
_swxApp.SendMsgToUser("Rosenxt AddIn reconnected");
catch (Exception ex)
Console.WriteLine(\\\$"Reconnect failed: {ex.Message}");
private void ConfigureComponentIdentifiers(IFeatureManager featureMgr)
int identifier = featureMgr.ComponentPrimaryIdentifier;
if (identifier != 1)
featureMgr.SetComponentIdentifiers(1, 8, 0);
featureMgr.SetComponentIdentifiers(1, 16, 0);
featureMgr.SetComponentIdentifiers(1, 4, 0);
else
featureMgr.SetComponentIdentifiers(2, 8, 0);
private void SubscribeToSaveEvents(ModelDoc2 modelDoc)
switch ((swDocumentTypes_e)modelDoc.GetType())
case swDocumentTypes_e.swDocASSEMBLY:
_assemblySaved = OnAssemblySave;
(modelDoc as AssemblyDoc)!.FileSaveNotify += _assemblySaved;
break;
case swDocumentTypes_e.swDocPART:
_partSaved = OnPartSave;
(modelDoc as PartDoc)!.FileSaveNotify += _partSaved;
break;
case swDocumentTypes_e.swDocDRAWING:
_drawingSaved = OnDrawingSave;
(modelDoc as DrawingDoc)!.FileSaveNotify += _drawingSaved;
break;
private int OnAssemblySave(string docFileName) => ZoomToFitActiveDoc();
private int OnPartSave(string docFileName) => ZoomToFitActiveDoc();
private int OnDrawingSave(string docFileName)
if (_swxApp?.ActiveDoc is DrawingDoc drawingDoc)
if (drawingDoc.GetEditSheet())
drawingDoc.EditTemplate();
drawingDoc.EditSheet();
drawingDoc.ForceRebuild();
return 0;
//private int OnCommandCloseNotify(int command, int reason)
// if (command is (int)swCommands_e.swCommands_Save or
// (int)swCommands_e.swCommands_SaveAll or
// (int)swCommands_e.swCommands_SaveAs)
// ZoomToFitActiveDoc();
// return 0;
private int ZoomToFitActiveDoc()
if (_swxApp?.ActiveDoc is IModelDoc2 modelDoc)
modelDoc.ShowNamedView2("", 7);
modelDoc.ViewZoomtofit2();
return 0;
public bool DisconnectFromSW()
_reconnectTimer?.Stop();
_reconnectTimer?.Dispose();
if (_swxApp != null)
//_swxApp.CommandCloseNotify -= OnCommandCloseNotify;
_swxApp.SendMsgToUser("Rosenxt SolidWorks AddIn unloaded");
if (_partSaved != null && _swxApp?.ActiveDoc is PartDoc partDoc)
partDoc.FileSaveNotify -= _partSaved;
if (_assemblySaved != null && _swxApp?.ActiveDoc is AssemblyDoc assemblyDoc)
assemblyDoc.FileSaveNotify -= _assemblySaved;
if (_drawingSaved != null && _swxApp?.ActiveDoc is DrawingDoc drawingDoc)
drawingDoc.FileSaveNotify -= _drawingSaved;
SolidWorksConnector.ReleaseComObject(_swxApp);
_swxApp = null;
return true;
