Hello All,
Actually I am struggling with an example problem given in Abaqus Manual 6.14. Link to the example is http://www.egr.msu.edu/software/abaqus/Documentation/docs/v6.7/books/exa/default.htm?startat=ch09s01aex128.html
I am new to Abaqus and I am not sure if I am using a correct procedure to run the example given?
My understanding
There are two files given in the example viz; .inp and .f
.inp is input file
.f is subroutine file
I copied the .inp content in a notepad.
Made nescessary changes as said in the .inp file.
Further saved the modified notepad file with .inp extension
Now, I copied .f file contents in a notepad and saved this notepad file with.f extension
All the files are saved in the default folder.
Further, to run the input file, I used "abaqus job= file name without .inp extension"
Multiple files got generated. But, what about the .f file? Where should I use it???
Is this procedure correct?? If not what will be the procedure??? (Note: I have Fortran installed and is called for when I open Abaqus command box)
Please guide and suggest!
Thanks & Regards,
Aditya Nikam
