I am currently working with Process Composer to set up an optimization workflow.
The sequence I want to achieve is as follows:
- Parameter model (design variables) →
- DOE (Design of Experiments / parameter study) →
- Approximation model (RSM, surrogate model, etc.) →
- Optimization
In other words, I want to use DOE to sample design variables, run simulations for those samples, build an approximation model, and finally perform optimization to obtain the best design.
However, when I try to build this in Process Composer, I run into some issues:
- The Optimization block seems to exist independently and cannot be placed inside the DOE block.
- As a result, the Optimization step cannot directly read the variables defined in DOE.
👉 My questions are:
- What is the correct way to arrange DOE → Approximation → Optimization in Process Composer?
- Do I need to expose or configure the DOE variables/outputs separately so that the Optimization can access them?
- In practice, what is the recommended workflow setup for this sequence?
Any advice from those with experience would be greatly appreciated.
Thank you!
EX)
0
