Problem in robot simulation
Hello All,
I have a problem where i get this text in a window:
''Object : Behavior00005011 A.1
Problem :
Problem while loading data. [ERR_101]The links cannot be loaded due to inconsistencies between authoring stream and relations. A possible reason for this problem could be a concurrent modification/deletion of the associated component. In such case close session and retry operation. If the problem persists try running the tool CATPLMComponentCheckerBatch (Tools\\Utility) on 'bhv-R1132100675044-00005011'. If the issue is not fixed, then try the tool CheckRepresentation with the rule DOC_5 activated. Technical details: Links inconsistency on component (Behavior,C115FBD700003D50623AEE1B0002F2EF).''
After this problem has arisen, i am not able to see my robot operations in the teach window or in the sequencing window. Is there a solution for this?
Thank you in advance
