Hello
In the process of saving in DELMIA Robot Simulation, turning off the file, shutting down 3D Experience, and checking if the storage is good, an image-like error occurred, and I would like to ask you how to solve the problem.
After the above problem occurs, the subtree does not come out even if you press the Behavior tree, and an error message such as the image is displayed, so even if you enter the Sequencing Tab, the task is in the subtree that you created
I can't see it.
The content of the Incident report is this.
- Problem :
Problem while loading data. [ERR_101]The links cannot be loaded due to inconsistencies between authoring stream and relations. A possible reason for this problem could be a concurrent modification/deletion of the associated component. In such case close session and retry operation. If the problem persists try running the tool CATPLMComponentCheckerBatch (Tools\\Utility) on 'bhv-R1132103274776-00005861'. If the issue is not fixed, then try the tool CheckRepresentation with the rule DOC_5 activated. Technical details: No relation for IDRel=2 on component (Behavior,E325EF7A000009886886FD5500362FA3).
Please check and reply quickly.
