I am developing an EKL script to import a manufacturing workplan into 3DEXPERIENCE 2025.
Our intended structure uses:
- One shared primary resource instance for the entire workplan.
- One instance per distinct tool in the workplan’s resource positioning AREA.
- Reuse of the same tool instance by several operation steps, including steps belonging to different Header Operations.
I am using the DS example based on CreatePrimaryCapableResourceLink, CreateSecondaryCapableResourceLink and SetRscUsageOnCapableRscLink as a starting point.
I need to create resource usage details for individual operation-step occurrences, whose reference type is DELLmiGeneralOperationReference, and set their usage mode to StepOnly.
CAA implementation uses DELIPPRRscPositioningMngt:
CreateCapableRscDetail(secondaryLink, stepOccurrence, resourceDetail);
SetAvailabilityMode(resourceDetail, AvailabilityModeCAA::StepOnlyCAA);I found GetRscLinkDetailsFromCapableRsc for reading existing usage details, but I need to create them and set their availability mode.
The DS tutorial “Import System Structure From Excel with Capable Resources”, validated on 2026x GA, states that setting child-operation resource usage modes is not available through EKL and requires manual UI interaction.
Could you please clarify:
- Does this limitation apply to all 2025x levels? Is there a supported EKL function or alternative for these two CAA calls?
- Can the primary and secondary resource links be attached at workplan level and used by steps under different Header Operations? If not, what supported link structure would preserve one tool instance per workplan?
Could you provide the function signatures, expected argument types, and a short example reusing an existing tool instance?
Thank you for your help.
