Add restrictions to "ManageWorkCenter" BusinessComponent.
Hello again. I wanted to ask about the "ManageWorkCenter" Buisness Component(BC). Specifically, this component's current ability to both Update and Create a WorkCenter.
Due to how we intend to implement WorkCenter Creation and WorkCenter Updates, I need a way to ensure that I can avoid updating an existing WorkCenter by accident.
An example of the current flow that has the potential to cause problems:
1) Open the "New WorkCenter" page. Input WorkCenter1, & relevant Data => Data arrives at ManageWorkCenter BC.
2) ManageWorkCenter finds an extant WorkCenter1, and updates WorkCenter1.
An example of the flow I want:
2) ManageWorkCenter finds an extant WorkCenter1, and returns an Error message stating "WorkCenter1 already exists"
The same applies for the Update process. The UI is locked down and takes data from a DataGrid selection, so it should not create a new WorkCenter. But I would feel safer if I could add a restriction of some sort.
I am currently looking at the "flx_spWorkCenterInsert" Stored Procedure as an alternative.
Edit: So, I've slept on this a bit. And the idea I have right now is to run a validation before bringing the data to ManageWorkCenter. I would run an SQL query with the inbound data. (WorkCenter, Facility, Division, Department), then based on the output (Count = 0) or LastDeleteOn value (If a matching WorkCenter was deleted previously) , send an error, or proceed to the ManageWorkCenter BC
Flow : NewWorkCenterScreen => Input WorkCenter1 & Relvant Data => SQL Query for matching database values. If matching values are found, cancel the operation, unless[LastDeleteOn] is not null or 01/01/1900 12:00:00 AM.  => Send data to ManageWorkCenter
In my opinion, this still has a risk of updating the "deleted" entry.
Any pointers towards documentation, or help would be greatly appreciated. Thanks in advance!
