Hi there,
I have a few questions regarding the nesting operator.
First, the "rotations freedom" option:
It seems that this option does not work when the selected parameter "None" is active.
Even when selecting the "None" parameter, the input objects change orientations during the nesting operation :
On the left the part in blue before the design sequence, on the right the nested part after the design sequence, with the "none" parameter active in the nesting operator for the "rotations freedom" option.
We can see that the orientation of the part is different, despite the option activated.
Second, the nesting calculation:
I find the result of the nesting operation strange and unexpected, it seems that all the input objects have been nested along a direction in the center of the support surface :
The result of the nesting calculation does not look optimal, the expected nesting result is something like this :
Is my use of the nesting operator incorrect?
Do you have a solution to allow me to obtain the expected results for my two questions?
Thank you very much!
