Hello everyone,
We are currently developing a carbon fiber monocoque for a lightweight vehicle using 3DEXPERIENCE CATIA Composites Design with the Grid Design approach.
The structure includes several geometric steps and transitions, particularly around the door and window openings, where recessed areas and flanges are required.
I am currently investigating the best approach for handling these geometric features in composite design.
One possible approach is to integrate the steps directly into the reference surface, as shown in the attached screenshots. However, I am aware that such geometries can cause difficulties when calculating composite thickness offsets and top surfaces.
Current situation:
- The Grid Design and ply definitions work as expected.
- The plies are generated successfully.
- The ply ramps are calculated correctly and follow the intended geometry.
- However, problems occur when calculating the Top Surfaces, particularly around the stepped transitions.
- These Top Surfaces are required for the subsequent definition and generation of sandwich cores.
My questions are:
- How are such geometric steps typically handled in industrial composite design workflows, particularly around doors and windows?
- How would you approach the definition of sandwich cores in these areas while maintaining an associative design?
The screenshots show only a preliminary test layup and grid, which I am using to establish and validate the overall composite design workflow before developing the final laminate.
I would appreciate any recommendations, practical experience, or examples of similar applications.
Thank you in advance!
