Morning,
Please find included an MDZIP file with most of the structure that I am asking for help with. The actual model has nothing to do with XMAS, but I wanted to give a better? starting point that just text.
- I have learned that REDEFINE only works at a one level or child relationship.
- Thru You Tube and ChatGPT, I thought I had found an answer in using "isSubstitutable" for the "SelectedILP : ILP" part within the ILP block (along with some pointers via constraint/para)
BUT, "isSubstitutable" is not to be found, even with expert mode.
The goal is, if I have a major component of a larger system, that has multiple parts/configuration possibilities (see ILP BDD) is it possible to setup the model, kind of like the more basic REDEFINE, where in a sim/run environment we could select between ILP_1 and ILP_2 and the values would Populate up to the "Parent" ILP block for use in analysis.
Thank you for any advice or guidance.
V/R Joe
P.S. ILP = Intergrated Launch Package
