G'day,
We're using Pipeline Pilot 8.5.
I'd like to fetch data from a web-service available on our intranet. It uses Windows Authentication.
I've been trying to access this service using the SOAP Method with WSDL Support component. I point the component at the WS's WSDL URL, and it loads and parses the WSDL correctly. I select a method name and set the appropriate input and output parameters but when the component's protocol is run I invariably get an Unable to authenticate error (see below).
I've tried supplying my Windows credentials as the HTTP Transport security and SOAP message security parameters but to no avail. I've also tried using my Pipeline Pilot credentials.
Are there additional steps that are needed to get SOAP Method components working Windows Authenticated web-services?
Thanks,
Chris.
CHttp::CheckResponseHeader: Pipeline Pilot exception rethrown
CHttp::internalOpen: Pipeline Pilot exception rethrown
CHttp::Open: Pipeline Pilot exception rethrown
vcFile::Open : Failed to open XXXXXXXXXXX: Exception caught
CWsdlParser::parse(): Pipeline Pilot exception rethrown
CWsdlParser::loadExternalSchemata(): Pipeline Pilot exception rethrown
CWsdlParser::GetSchemaInfo(): Pipeline Pilot exception rethrown
CWsdlParser::GetSchemaForPartDoc(): Pipeline Pilot exception rethrown
CWsdlParser::GetMatchingSchemaElementDoc: Pipeline Pilot exception rethrown
CWsdlParser::IsOfAtomicTypeDoc(): Pipeline Pilot exception rethrown
CSoapExecute::addPartToMethod(): Pipeline Pilot exception rethrown
CSoapExecute::executeOneRecord(): Pipeline Pilot exception rethrown
CSoapExecute::onProcessNew(): Pipeline Pilot exception rethrown
CSoapExecute::onProcess: Pipeline Pilot exception rethrown
-> SOAP Method with WSDL Support (SOAP Method with WSDL Support__{28ED86C6-9B46-4AE6-A65D-A7FE96D7E5B0}) - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
Protocol New Protocol1, user cpudney: Pipeline Pilot exception caught
Protocol New Protocol1, user cpudney: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 8.5.0.200
Server OS: Linux XXXXXXXXX 2.6.18-194.11.1.el5 #1 SMP Tue Aug 10 19:05:06 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
