Author: Unknown
Version: 1.0
Created: 2003
Purpose: This will allow you to choose data points within Spotfire and pass that information back to a Pipeline Pilot protocol
Requirements: Pipeline Pilot 6.0 or later
Spotfire Decisionsite
O/S: Windows and Linux
Keyword: Spotfire interactive filter
Contents: distribution.zip (the module to install on DecisionSite Server)
Spotfire Filter.xml (the PipelinePilot component & protocol)
README.txt
Installation:
1. Save distribution.zip to disk (it does not need to be on the server).
2. Open a DecisionSite Client with network connection to server.
3. Login to the server using Tools->Administration->DecisionSite Administrator.
4. Enter username and password.
5. Choose Deployer from the top-level menu.
6. Browse to the location of distribution.zip.
7. Choose deploy.
Additional clients will still need to connect to the server to update. To update a Spotfire DecisionSite client, all that is needed is to login to the server:
1. Open DecisionSite.
2. Choose File->Login to Server.
3. Enter the location of the server and username and password, and the server is updated automatically.
To install the Pipeline Pilot component:
1. Open PipelinePilot.
2. Drag the Spotfire Filter.xml file onto the Pipeline Pilot client into the explorer window. (To make it visible to other users, save in the Protocols or Components tab.)
To use the filter:
1. Run a protocol that contains a Spotifire Filter component.
2. When the DecisionSite window is displayed, ctrl-click the records of interest.
3. Click "Return to PipelinePilot" in the displayed pop-up.
4. The protocol routes the selected records to the Pass Port, the remaining records to the Fail Port.
