Run Command SSH Component
I'm trying to use the 'Run Command SSH' component to execute some commands on a linux machine. Specifically I want to be able to execute a python script that is currently located in the linux directory.
I am able to connect properly to the machine e.g.
cd sam;
touch test.txt
(this produces the text file in the correct linux directory sam)
This is the code I am trying to run, it executes ok when run in linux but when I try it using the SSH component to execute the code nothing seems to happen
cd sam; #changes directory to the one of interest
module load python #loads the python module
python test.py #runs the python script
The contents of the test.py file
test_file = open("test.txt","w")
test_file.write("Hello WOrld")
test_file.close()
Is this kind of thing possible using this component?
Can anyone help with this or suggest an alternative?
Thanks,
Sam
