Problems with .NET Client API
I'm having an issue with the .NET API when used from VB 2008.  The  function call is simply:
j.SetInputFileOnClient("FileName", New System.IO.FileInfo(InputFile))
for which I have a parameter set up on the PP protocol and a valid reference to a local file in InputFile.
It throws an error, but the only available message is 'Error occurred while uploading file to server at E:/Program Files/Scitegic752/web/jobs/davies_dc/{nlp278F9-5C90-4EFB-B284-D3815AE74F03}/input'
The InnerException is not very helpful either.
Anybody else seen this error?
Answers 6
WH
WH 2010-07-28
The examples are on the server in the clientsdkdotnet package. If you don't have filesystem access, you can get the source for this example from the developer documentation, which contains the complete code. But I would suggest asking an admin to zip the entire apps/scitegic/clientsdkdotnet directory for you so you get the Visual Studio 2003 solution files (in 8.0 we upgraded these to Visual Studio 2008).
I would suggest upgrading to the latest version of nalpp.dll, which can also be obtained from the server's clientsdkdotnet/bin directory, and see if that makes a difference.
A useful trick for getting files from the server to your desktop is to use the Copy to Client component. Edit the component and change the type of the source parameter to URLType. Then navigate to the file you want by selecting the "Server Root" shortcut, navigating up one directory, and then going to apps/scitegic/...
WH
WH 2010-07-28
Come to think of it, the version of the Pipeline Pilot server and the the version number of the nalpp.dll you're currently using would also be invaluable information.
CD
CD 2010-07-28
I realised I left this info out and so edited the original post immediately afterwards to give you the version of the server (7.5.2.500) and the nalpp.dll (6.0.1.100) but the edits don't seem to have 'taken'.
The client OS is Windows Vista Enterprise SP1, and I'm building against .NET 3.5.
Is that example on the server installation?  I can't seem to find it on the client
WH
WH 2010-07-28
We haven't seen any problems related to this call in our tests. Can you provide a bit more information to see if we can reproduce it?
* What is the client OS?
* What version of .NET are you building against?
What happens if you build and execute the SimpleSynchronousRun example that ships in the .NET development package. The path is
\apps\scitegic\clientsdkdotnet\web\examples
Do you get the same error?
Thanks,
Warren
CD
CD 2010-07-29
Nice idea, but our system admin is a canny customer, and he's stopped us from doing that!
I'd better wait until he gets back from his holiday.
HP
HP 2012-05-09
I've also encountered exactly the same problem. It seems to occur with version 7.5.2.300 of the nalpp.dll assembly, linking instead to version 8.5.0.0 resolved the probelm for me.
Hope this helps, in case this helps anyone stumbles across the same thing again.
R/Johan
