Pet Peeves from BIOVIA Pipeline Pilot User Forum
Hi Everybody,
We’ve heard you and collected your pet peeves from last month’s User Forum in Frankfurt, Paris and London.  Here is the list.  Updates will come in the following weeks as we work on fixing the bugs and developing new features.
Pet PeeveAreaType
More control on chart such as tick mark….UIFeature
Not all viewer components have been updated to newer default browser functionalityUIFeature
Find next/previous in F11UIFeature
F11 should highlight text in pilotscriptUIFeature
PP has left-to-right paradigm. Have option to change this to top-to-bottom.UIFeature
Shortcut to select server first and not try last and then suggest listUIFeature
Make it more obvious which server we are working on (background color?)UIFeature
Webport ability to upload multiple files or a directoryUIFeature
Interface of parameters for shortcut are not (automatically) updated to other use of the shortcut (need to manually replace by latest version)UIFeature
Long integer is rendered in scientific notation in Html and then details of value can be lost if number is very long (browser number cut).UIBug
Protocol help from within Insight is just one line???UIBug
Allow PP users to find out what percentage of the available CPU power they are usingUIFeature
Ctr T is not accurate in a run-to-completion (RTC) subprotocolUIBug
CTRL T then close protocol memory not releasedFrameworkBug
Support case ion Linux 6/7 memory issue with reporting – case has been closed.FrameworkBug
Documentation for packaging a schedule jobFrameworkFeature
Copy to client for runprotocol command line, seems to be retired for security reasons => alternative needed.FrameworkBug
Package creation utilities from client to make it more user-friendly Developer toolsFeature
Better version control system as it is today (one version each time save, integration with 3rd party source code control))Developer toolsFeature
Better monitoring of memory for PP developer (not admin) at component level.Developer tools
NGS documentation for optimization of performances (multi threading, parallelization).CollectionsDocumentation
