I've downloaded the latest version of the OpenPHACTS collection and I'm running some tutorials on Pipeline Pilot 18.1.0.
I've imported components and protocols from the GUI app and used the APP Key retrieved from the website to configure the "OpenPHACTS Configuration" component.
When I run the with the before-mentioned component at the top, I get this error from the other components:
ErrorText:App ID is required and needs to be set either in the administration portal or using the OpenPHACTS Configuration component.
ErrorDetails:CEvaluateExpression::onProcess: Pipeline Pilot exception rethrown -> 'Custom Filter (PilotScript)' ('#pass := False;'); Location: 6:71:0 - Handled error during Data Record Processing phase (in 'OpenPHACTS Result Manipulation Example' ('OpenPHACTS Result Manipulation Example'); Location:): sent record to fail port
The API key has been created few minutes ago and the server status seems to be live. The OPS server URL in the component is "https://beta.openphacts.org/2.1" as mentioned in the help document.
