ODBC Insert record limit?
Is there a limit to the number of records you can insert into a table simultaneously using ODBC components? I am trying to add data to a table that has about 150 columns, but recieve the following error:
vcODBC::ExecutePrepared: Severe error caught
This does not show up if I cut the number of records to insert down to 50 or so. Is there any fix or workaround for this limitation? Thanks!
