Name: Notepad Reader & Notepad Table Viewer
Author: Christian Herhaus
Version: 1.0
Created: 8/2012
Modified: 8/13/2012
Purpose: Notepad Reader & Notepad Table Viewer extend Notepad-based functionality for easy import, export and presentation of pure alphanumerical data. The Notepad reader allows to directly input or copy data into a running protocol. For convenience, this data is stored in a server-based template so it is available again once the protocol is restarted. The Notepad Table Viewer displays data in a column-based table style within Notepad which may be simpler to use as other data viewers and moreover allows easy copy/paste of the data into other Windows software. The example protocol demonstrates a simple use case.
Requirements: Pipeline Pilot 8.5 or later
O/S: Windows and Linux
Limitations: none known
Keywords (tags): pipeline_pilot, library, notepad, reader, writer, table
Contents: Notepad Reader.xml, Notepad Table Viewer.xml, Notpad Reader Table Viewer Example.xml
Installation:
1. Unzip the archive.
2. Import reader/writer components and/or the example protocol into your user tab in the Pipeline Pilot client by dragging and dropping it in the Explorer window.
3. Open the example protocol.
4. Run the protocol and follow the instructions to explore the functionality.
