We have a mapped data drive with the structure \\\\Server_Name\\Dir\\\$ which is used to hold images to be process in PLP. I would like to map this drive using the file browser in the Admin portal. However, when I type the PATH in it says that this is not accessible, however if the same string is typed into a component with a Directory or URL type it can see these files just fine. When I force the addition of this drive by editing the Shortcuts.xml it the shortcut works when remote desktoping into the server PC but not on any client PCs or through the webport. Outside of renaming the folder (against company rules) what can be done to map this drive?
Thanks
Thanks
