Name: Join Data from Tag
Author: Jacques-Antoine Duret
Version: 2.0
Created: 10/2003
Modified: 08/16/2007
Purpose: This component works in a similar fashion to the Join Data from File or Cache components, except in this case, it joins properties from tagged records in the stream to records that are untagged.
Requirements: Pipeline Pilot 6.0 or later
O/S: Windows, Linux
Limitations: none known
Keyword: join data tag
Contents: Join Data from Tag.xml - new join component
Join Data from Tag Example.xml - an example protocol
Installation:
1. Unzip the archive.
2. Import the protocol into the Pipeline Pilot client by dragging and dropping it in the white workspace area.
3. Import the component into your user tab or on the Components tab by dragging and dropping the xml file into the Explorer window of your Pipeline Pilot client.
3. Run the example protocol.
