How to install Python3 packages?
G'day,
We are running PP 2019 on Red Hat EL 7.5.
We would like to install Python packages such that they're available to all of our Pro Client developers via the Python (on Server) component.
I see this component uses /apps/scitegic/integration/bin/lang/python. So, to install a package is it simply a matter of the server admin running (as the PP user):
/apps/scitegic/integration/bin/lang/pip3 install
I see that the Python (on Server) component has a PythonPath parameter that would allow for python packages to be installed outside the file tree but not all packages will work using the method if they have native libraries.
The pip3 approach seems simplest but are there any gotchas we should be aware of?
Thanks,
Chris.
Answers 2
MC
MC 2019-11-05 Best Answer
You have two main options here:
1. Install the additional packages into the instance of Python that ships with Pipeline Pilot.
2. Setup a separate installation of Python on the Pipeline Pilot server and add whatever packages you need to this. You would then  use either the "Use Package" parameter if your components are to be packaged,  the "PythonPath" parameter on the component OR the global property "BIOVIA/Integration -> PythonPath" (set in the admin portal) to point to where you have installed the extra packages.
There are pros/cons to both.
Installing to the Pipeline Pilot version of Python is as you say relatively simple - the downside is you need to maintain that setup through Pipeline Pilot upgrades etc
Having a separate installation is a more lengthy approach but it does mean you can work more easily with Python externally to Pipeline Pilot - and if you use the option in Pipeline Pilot 2019 to specify the location of the additional packages as a global property in the admin portal there is no need to specify this on each component. Note: the Python version you use needs to be compatible with the version used by the Pipeline Pilot server, in PP2019 this is Python 3.6
CP
CP 2019-11-06
Thanks @MC. It looks like option 1. isn't possible due to a bug(?)...
