Guidance Required: Adding Entries to XYZ Vocabulary Using Pipeline Pilot Protocol
Hi Team,
I am currently working on a requirement to add entries into the XYZ Vocabulary using a Pipeline Pilot protocol.
I would appreciate your guidance on the following:
What is the recommended approach to set this up in Pipeline Pilot?
What API calls need to be created or configured in PLP to support this?
Are there any reference protocols available for a similar use case?
Has anyone previously implemented this approach and can share best practices or examples?
Any documentation, sample protocols, or pointers would be very helpful.
Thank you in advance for your support.
