G'day,
I have a protocol that contains two sub-protocols which in turn contain SQL Select for each Data components. When I run the protocol I get the following error message:
CStdioFile: Unable to open file /apps/pp/web/jobs/cpudney/{ppcA4AD6-865A-A25E-BDF1-39E9F163F134}/_cptcache_/{A1F389FF-CEB1-4699-A6AD-FBC23E3ADE52}/CACkZdynj.tmp for reading: No such file or directory
Locating the error identifies the SQL component in the first sub-protocol. If I disable one of the sub-protocols then the error goes away.
Is the second instance of the SQL component cleaning up cache files that are still needed by the first instance?
Regards,
Chris.
Here's the full error stack:
vcFile::Open : Failed to open /apps/pp/web/jobs/cpudney/{ppcA4AD6-865A-A25E-BDF1-39E9F163F134}/_cptcache_/{A1F389FF-CEB1-4699-A6AD-FBC23E3ADE52}/CACkZdynj.tmp: Exception caught
vcByteArrayCache::DiskFileInfo::OpenFile: Pipeline Pilot exception rethrown
vcByteArrayCache::DiskFileInfo::ReadDataBlock: Pipeline Pilot exception rethrown
vcByteArrayCache::DiskFileInfo::GetDataBlock: Pipeline Pilot exception rethrown
vcByteArrayCache::FileInfo::ExtractDataBytes: Pipeline Pilot exception rethrown
vcByteArrayCache::GetDataBytes: Pipeline Pilot exception rethrown
vcCache::GetRecord: Pipeline Pilot exception rethrown
CDataCacheIO::onProcess: Pipeline Pilot exception rethrown
-> Fetch biology
(SQL Select for Each Data) - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
-> Get biology (Subprotocol) - error during Data Record Processing phase
-> EPS breakpoint (Local Shortcut) - error during Data Record Processing phase
-> Break pointing (Subprotocol) - error during Data Record Processing phase
CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
Protocol GHDC, user cpudney: Pipeline Pilot exception caught
Protocol GHDC, user cpudney: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 8.5.0.200
