Name: File and Property Selection Wizard
Author: Lynn Miller
Version: 1.0
Created: 4/2009
Purpose: interactive wizard that allows users to select the desired SD files from a list of vendor catalog files in a specified location, and for each of the selected files allows the users to select the property to use as the identifier so the inputs can be consolidated on this key, which varies by catalog, for use in a work protocol.
Requirements: Pipeline Pilot 7.0 or later, Reporting Collection, Chemistry Collection
O/S: Windows and Linux
Limitations: none known
Keyword: report wizard
Contents: vendorselection.xml, vendorfileselection-form1.xml, vendorfileselection-form2.xml
Installation:
1. Unzip the archive.
2. Import the vendorselection folder into your Protocol tab under Web Services in the Pipeline Pilot client by dragging and dropping it in the Explorer window.
