Name: Convert Record to Sequence
Author: Lynn Miller
Version: 1.1
Created: January 2010
Purpose: This component allows you to turn any property containing a sequence string into a sequence record for use with the Sequence Analysis Collection without having to start from a file in a standard sequence format.
Requirements: Pipeline Pilot 6.0 or later
O/S: Windows and Linux
Limitations: none known
Contents: Convert Record to Sequence.xml
Installation:
1. Unzip the archive.
2. Import the Convert Record to Sequence.xml file into your user or Components tab in the Pipeline Pilot client by dragging and dropping it in the Explorer window.
3. Use the Convert Record to Sequence component in your pipeline to convert sequence string properties on your incoming data records into sequence data records.
