Name: Cluster using Murcko Assembly
Author: Moises Hansan
Version: 1.0
Created: 10/2005
Modified: 7/2007
Purpose: Group molecules that share a common Murcko assembly. A Murcko assembly for each molecule is defined by its ring systems plus any chains connecting them. All aliphatic chains are trimmed from the molecule. Based on: "The Properties of Known Drugs. 1. Molecular Frameworks" Bemis, G. W., Murcko, M. A., J. Med. Chem., 1996, 39; 2887-2893.
Requirements: PP Server 6.1.1, Chemistry Collection
O/S: Windows and Linux
Limitations: Murcko assemblies are defined only for molecules with rings. Molecules without rings will be filtered out by this protocol. They will not appear in the final grouping.
Keyword: Murcko, rings
Contents: Cluster using Murcko Assembly.xml
Installation:
1. Drag and drop the XML file into the white workspace of the Pipeline Pilot client.
2. Run the protocol.
